Page 1 of 2
Contaminated Fresh water supply
Posted: June 18th, 2020, 11:43 am
by dkoons16
Have a 1998 400 CMY, just purchased. The water tank after, I filled it, became clogged with black slime at the filter. Cleaned it and worked for about 5 minutes. (Water pressure motor was ON). Came back to boat next day and turned everything on again, ran for 10 seconds and stopped. All faucets.
I'm assuming its the filter again. I know how to clean the tank, but I need to empty it first. Any tips or suggestions would be appreciated.
Thanks in advance,
D & D
Re: Contaminated Fresh water supply
Posted: June 18th, 2020, 12:05 pm
by tomschauer
I believe your tank is under the aft cabin bed. Open up the access port and use a larger pump without a filter or a shop vac to empty it and suck up the worst of the sludge.
Posted: June 18th, 2020, 12:25 pm
by Midnightsun
What he said, if it's like mine you will have a 4" diameter access port on top, suck everything out with a shop vac. Then rinse with a hose from the access port. I would then add some water and shock treat with bleach. Here is a picture of the access port on mine.
Posted: June 19th, 2020, 6:10 am
by dkoons16
Thanks, I will try that. I'm also having issues with the system holding pressure. Hopefully its only the clogged filter.
Posted: June 25th, 2020, 6:22 am
by dkoons16
Emptied tank and its in worse shape then expected. Has anyone replaced a tank? How difficult is it to do yourself?
Posted: June 25th, 2020, 7:14 am
by Midnightsun
Is the tank plastic or aluminum?
Posted: June 25th, 2020, 9:51 am
by tomschauer
It depends on the access. If you can easily remove and replace it without removing all kinds of other things its pretty easy.
You have a fill line, vent line and outlet to the pump. Maybe a level sensor.
Posted: June 26th, 2020, 5:49 pm
by dkoons16
Midnightsun wrote:QR_BBPOST Is the tank plastic or aluminum?
Plastic tank
Posted: June 26th, 2020, 6:11 pm
dkoons16 wrote:QR_BBPOST Emptied tank and its in worse shape then expected. Has anyone replaced a tank? How difficult is it to do yourself?
A plastic tank that is not leaking ??.....why not just clean it as has been suggested.....that will be much easier to clean than replace. Just need a shop vac and some brushes.
Posted: June 26th, 2020, 7:57 pm
by Midnightsun
A plastic tank is good forever. Just a good cleaning a some disinfecting with bleach and same as new. Just decommissioned mine last week as sit on the boat typing this drinking water from my tap. :captain2:
