Replacing Fireboy Halon 100cg
mitchellp
Vessel Info: Carver 1989 38 Aft
Post by mitchellp »
Hi,
I have 1989 Carver 3897 aft needing to replace fireboy halon suppression system. Could not find any instructions how to remove safely.
Please advise. Thanks
Mitch
2001santego
Vessel Info: 2001 Carver Santego 380
Twin 496 Mercruiser 8.1 Horizon
Inboard with Walter V-Drives
7.5kW Koehler Gen
Been thanked: 4 times
Re: Replacing Fireboy Halon 100cg
Post by 2001santego »
Mitch, I believe Fireboys self contained units all have a fusible link or glass bulb that will melt/ break at 175 F. Steel wire shroud prevents accidental release Some units have a cable that can break the glass bulb to manually release the agent. If you have the cable, or hitch pin assembly, carefully remove it, then you should be able to unbolt the tank clamps and carefully remove it. I would bring it to a certified fire extinguisher company and have them certify the tank, the gauge and recharge it.
Tony T
‘95 Sea Ray Sundancer 230 5.7L Mercruiser I/O GenII
‘01 Carver Santego 380 Twin 8.1L Mercruiser Horizon Inboard w/ Walter V Drives
edw
Vessel Info: 1983 3607
Post by edw »
CAUTION!!! Halon is DEADLY! Be extremely careful.
2001santego wrote:QR_BBPOST Mitch, I believe Fireboys self contained units all have a fusible link or glass bulb that will melt/ break at 175 F. Steel wire shroud prevents accidental release Some units have a cable that can break the glass bulb to manually release the agent. If you have the cable, or hitch pin assembly, carefully remove it, then you should be able to unbolt the tank clamps and carefully remove it. I would bring it to a certified fire extinguisher company and have them certify the tank, the gauge and recharge it.
^^THIS. I wouldn't just replace it 'just because it's old'. Many can still be serviced and Halon was a great extinguishing agent.
Check, but I thought Halon wasn't an option anymore.
Post by tomschauer »
I think you can still get reclaimed Halon to recharge your extinguisher. But if it has failed, its most likely cheaper to get a new FM bottle.
If its not failed, you can have it checked, weighed and retagged for most likely less than $50.
