ACR and switches question
- mikesparker
- Vessel Info: 1985 3227 w/Crusader 220s
- Has thanked: 28 times
- Been thanked: 3 times
- vineyardgray
- Captain
- Has thanked: 125 times
- Been thanked: 32 times
- Contact:
Re: ACR and switches question
The wiring on my boat was a head-scratcher as well and I finally just had to pull out the multi-meter and dig into it.
I'm not certain why they would have added two blue-seas ACR switches to your boat, but they can be used for a variety of applications.
The non-charging situation could just as easily be from someone switching the on-off-all switch while the engines were running and blowing the diodes of the alternators. hopefully that isnt the case.
some pictures might help?
1988 Carver
3867 Santego
PCYC
- mikesparker
- Has thanked: 72 times
- Been thanked: 1055 times
You will need to map out the wiring, because there are 100 ways to interconnect stuff and folks will do it differently for a variety of reasons. If you can trace some of the wires and draw a simple diagram we might be able to help much more.
- mikesparker
Do either of the ACRs have lights on them when the engine(s) are running?
- mikesparker
- Has thanked: 457 times
- Been thanked: 1697 times
- mikesparker
There are no lights in the ACRs when the engines are running.
I've got some pics of the wiring to the back of the ACRs and switches that I'll have to edit and post later this evening.
Also noticed that my #2 starting battery isn't getting charged with shore power, but #1 starting and house bank are.
km1125 wrote:Source of the post On the ACRs, check that the ground connection is good. If there's a fuse or breaker in that circuit (would only be a small fuse or breaker) then make sure they are good too. Sometimes during winterization those are removed so that there is no drain from the ACR monitoring circuit while the boat is laid up. It's a very, very small current, but over months it adds up.
- mikesparker
