Generator
- Thepearl87
- Vessel Info: 1987,Carver 3607
- Has thanked: 3 times
Generator
Kohler model 7.5, R27. Ran fine. Just shut down like it was turned off. Found blown cranking relay fuse. Replace fuse (3 times). Nothing. Now does not blow fuse, but nothing at either test position, or remote. Battery good. New solenoid.
Any ideas???
Any ideas???
Re: Generator
Did the fuse actually blow three times and needed to be replaced, or you just replaced it once because it was blown and then a couple times "just in case it was bad"??
Don't think the cranking relay fuse would cause the genset to quit running, so I'm wondering what else could be common with that fuse.
- Thepearl87
Re: Generator
km1125 wrote:Qr Bbpost Did the fuse actually blow three times and needed to be replaced, or you just replaced it once because it was blown and then a couple times "just in case it was bad"??
The fuse blew 3 times, then did not blow anymore. I'm going to trace wires from that fuse to be sure there are no voids. If I jump the solenoid contacts, the unit turns over well. But no start. I have jumped the low oil wires, as well as the over heat wires also. Now it's above my feable generator knowledge.
- Thepearl87
Re: Generator
Excuse me if I do not reply promptly. I am new to this site and trying to navigate through it. I'm not sure where to find replies to my post.
Re: Generator
Do you have a wiring diagram or schematic of the R27? I poked around a little bit but could not find one online. I'm sure there's one out there if you searched enough though. That would help narrow down what could be the culprit or at least where to focus your search.
- Thepearl87
Re: Generator
If you get a chance, scan it or take a pic of it and post it. Might help us understand what you're dealing with so we can offer appropriate suggestions. Pics of the genset and/or control panels itself can help too.
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: Generator
I have a Koehler 7.5 Service manual in pdf. Send me an email and I will forward you a copy.
if there’s a way and someone will let me know I can post it on the site here.
Ron
“Escape Plan”
Murray, KY
“Escape Plan”
Murray, KY
- Thepearl87
Re: Generator
thepearleightseven@gmail.com
Thanks, I'll print it out when I get it.
I 4hink I have a faulty circuit board. I have it out being tested.
- ColRon
Re: Generator
Thepearl87 wrote:Qr Bbpost thepearleightseven@gmail.com
I have sent the service manual in pdf copy to your email.
Ron
“Escape Plan”
Murray, KY
“Escape Plan”
Murray, KY
