466 MY swim platform
Posted: November 7th, 2021, 8:10 am
by ems05#05
looking to mount a dingy caddy on my platform , could someone confirm if there are two metal plates built into the platform?
Re: 466 MY swim platform
Posted: November 8th, 2021, 2:17 pm
by Schoony
You can crawl inside your swim platform from the aft tall closet by the bathroom door, there is a access panel in that closet that gives full access to the inside of your swim platform, i have a davit system on my 466 which they installed steel backing plates inside the swim platform. not a hard install to do.
Posted: November 8th, 2021, 5:00 pm
by ems05#05
thanks for the info, did you thru bolt all way or screw it down . the lift comes with toggle bolts but i would rather not go all the way thru
Posted: November 8th, 2021, 5:39 pm
by Schoony
Yes, You have to go tru for it to hold properly, send me your email and i can send you some pics of the system i have on my 466.
Posted: November 8th, 2021, 5:51 pm
by ems05#05
cres05ems@gmail.comthanks for the help
Eric
Posted: November 8th, 2021, 7:54 pm
by Tireless
I have a different boat, however, I had two aluminum supports running front to back, in the core of my swim platform between the upper and lower layers of fibre glass. I was not able to see the aluminum stripes from underneath. It is aluminum, so you can drill trough it If you hit it.
I was advised by Carver that they were there and I did drill through one doing my install.
Greg
Posted: November 8th, 2021, 10:52 pm
by ems05#05
I was told there were two plates built into the platform, i guess i will find out soon enough
Posted: November 9th, 2021, 8:38 am
ems05#05 wrote:Qr Bbpost I was told
Tireless wrote:I have a different boat, however, I had two aluminum supports running front to back, in the core of my swim platform between the upper and lower layers of fibre glass. I was not able to see the aluminum stripes from underneath. It is aluminum, so you can drill trough it If you hit it. ....
That's the kind of information that would be GOLDEN to have in the owner's manual or other documentation provided with the vessel!!
Posted: December 10th, 2021, 11:19 am
by Tbw5959
ems05#05 wrote:Qr Bbpost I was told there were two plates built into the platform, i guess i will find out soon enough
Eric, Would you please keep us posted on this? We've just recently acquired a 466 also -- and thinking along the same lines.
Thank You!
Ted
Posted: January 9th, 2022, 11:15 am
by ems05#05
There is a metal plate extending from the edge of the platform almost to the deck box
