removing old 4" exhaust hose
Posted: January 9th, 2022, 5:22 pm
Hi, hello.
I need to get at my Velvet Drive transmission and take it out to be rebuilt.
My 350 Crusaders are FWC, coolant and a heat exchanger each, instead of raw water in the engine block.
There are so many hoses in the way!
What's worse, the exhaust elbow, that does a 90 to to meet the other exhaust hose, is fiberglass.
I have the hose clamps off. The hose does not want to move. It's been baked and pressed on there for years.
Usually, I pry the hell out of the hose end to get it off the lip.
In this case, I dont want to crush or pierce the fiberglass elbow and buy another one.
I might have to cut along this foot longish piece of exhaust hose, destroy it and buy another one.
That would be better than wrecking the 90 elbow, I figure?
The 4" exhaust hose that's in there now says "1993" on it, in the blue stripe with the hose info.
The boat is a 1994 production year, does this mean the exhaust hose could really be that old?
It would be a coincidence if not, that this unrelated number would randomly match the year this boat was constructed.
If the hose is that old, I don't feel too bad about wrecking a piece of it. Maybe it should all be replaced if it's that old?
Seller said he redid the exhaust hoses, and they look much newer than 1993 though.
Any tricks to removing old 4" exhaust hose? I'm trying to warm it up with a space heater and boiling water, but it won't budge. I've tried putting a piece of 2x4 in the inner crook of the elbow where the other hose clamp protects the lip from impact, and hammering the other end of the 2x4, to push the elbow out of the hose. No luck so far.
Soon the angle grinder and exhaust hose will have an encounter, unless something brilliant happens.
I have and will have a lot of questions as I try to repair this old beast. Thanks for reading these and for your help.
I will mail beer to all of you I guess?
