PCM 351W Casting (frost) Plug(s)
Posted: May 31st, 2022, 11:00 am
Has anyone attempted and been successful replacing the casting plug behind the engine mount on a Starboard PCM 351W in a Mariner without entirely removing the engine?
Got her in the water over the weekend and when I got her running I noticed it was weeping out pretty good, I got one of the rubber temporary plugs just to get her off the wall and into our slip. When I went to give it a tap to get it out the drift went through like it was tin foil. The mount is so close I could only fit the rubber plug itself without any of the plate/hardware with it. That being said it makes a pretty little stream when running. No water in the oil
. Thinking if I remove that headbanger cockpit floor I might be able to gently support the engine from above just enough to move it above the mount or pull the mount from under it to access the plug. If anyone has had any luck with this contortionists act please let me know.
Yes I ordered a complete set of brass to replace it and any other even remotely showing signs of distress.
