NEED PROPS
Posted: July 7th, 2022, 5:13 pm
by jimpeter
42 MARINER 2004. VOLVO GAS ENGINES LOOKING TO PURCHASE 2 PROPS. ANYONE KNOW WHERE I CAN??
Re: NEED PROPS
Posted: July 7th, 2022, 5:46 pm
by C0ps
jimpeter wrote:Qr Bbpost 42 MARINER 2004. VOLVO GAS ENGINES LOOKING TO PURCHASE 2 PROPS. ANYONE KNOW WHERE I CAN??
Check Face Book Market, Thats where I found Mine
Re: NEED PROPS
Posted: July 7th, 2022, 6:48 pm
by waybomb
So far, 4 boats, and for each I bought spares on ebay.
Way cheaper than new from a marina, and all but the 3 cleavers, were all brand new.
I didn't need the props, I just wanted spares, so I had time. If you need them right now, you may need to shop supply houses for the best deal though.
I bought brand new spare Michigan wheels for the 3697, 600 bucks for the pair. You can get a good deal if you have the time.
Re: NEED PROPS
Posted: July 8th, 2022, 9:38 am
by jimpeter
ANYONE KNOW HOW I CAN FIND OUT THE EXACT INFORMATION ON THE TYPE OF PROP I HAVE? MANUAL STATES... HAWBOLDT INDUSTRIES PROP 24X24 DQBZ MG4 1-3/4
PROPS
Posted: July 8th, 2022, 9:43 am
by jimpeter
HOW CAN i READ THE DESCRIPTION ON MY PROPS. MAUAL STATES. TRYING TO BUY NES SET BUT VENDORS ARE ASKING FOR PITCH, CUPPING, ETC. CAN ANYONE HELP OUT....CARVER 42 MARINER.. HAWBOLDT INDUSTRIES PROP 24X24 DQBZ MG4 1-3/4
Re: NEED PROPS
Posted: July 8th, 2022, 10:03 am
That would be a 24" diameter 24" pitch with a 1-3/4 shaft. I would not expect it to be cupped out of the factory, but you never know what a previous owner might have done. You can usually double-check the shaft size by measuring where it comes into the boat.
If you don't have any spares (and I'm a FIRM believer that you should), then you if you could find a set CLOSE to those 24x24 specs for a good price, then I would pick them up and use them and eventually convert them to your spares when you find the permanent set. As long as the shaft size is the same, they will work but may not be optimal. Say, you might find a set of 24x22 or 23x23 or even a set of three blades vs the four that you presently have. It will get you back on the water. You can continue to search for an exact match for your permanent set, or you might run on those spares and find that you'd like to change from the OEM prop to something else for better performance on how YOU use the boat.
Re: PROPS
Posted: July 8th, 2022, 12:19 pm
by waybomb
24 x 24 is diameter x pitch
1 3/4" is shaft size
Re: PROPS
Posted: July 8th, 2022, 2:05 pm
by buster53
What’s wrong with the old ones? Unless they are mangled, there’s a decent chance a good prop shop can fix them. Took mine in for service as one had a blade a little out of pitch. Looked brand new when I picked them up and had a prop scan report to go with them.
Re: NEED PROPS
Posted: July 8th, 2022, 2:26 pm
by buster53
Have you tried Google? Lots of prop shops out there and for something like you are looking for, I prefer buying local. You might want to let us know where you are located as we might know of a good shop near you.
