My Blower motor on my Marine Air has frozen
jwrape
Vessel Info: 79' Carver 28 Mariner Twin Pleasurecraft 302's (For Sale $12,300)
85' Carver 3207 Aft with Mercury 5.7L
Post by jwrape »
I have qa Ocean Breeze Marine reverse Heat Pump system on my Mariner 28'.
Over the winter the blower motor has stopped. I can turn it by hand but the motor is too stiff to spin by power.
Does anyone know how to fix this?
Been thanked: 492 times
Re: My Blower motor on my Marine Air has frozen
Post by waybomb »
I have no idea on your ac unit, but on other motorized things that froze up, I removed the motor, seperated the halves, pulled it apart, cleaned the bushings and shaft, lubed the bushings with light grease, reassembled and they lasted forever.
Worse that could happen is you'd have to buy a new motor. Hopefully, it's a standard motor you can buy at Granger store.
jwrape
Post by jwrape »
waybomb wrote:I have no idea on your ac unit, but on other motorized things that froze up, I removed the motor, seperated the halves, pulled it apart, cleaned the bushings and shaft, lubed the bushings with light grease, reassembled and they lasted forever.
I am hoping that works cause the OEM one is $295 plus shipping from Ocean Breeze
