AC water pump/ strainer and valve location ?
Posted: August 25th, 2023, 10:17 am
by REPOSE
Just put my new to me Carver 2827 Voyager in the slip yesterday , having trouble finding the thru hull connection and pump. There is no water flow through the unit and there for is not cooling. Thank you in advance for your help.
Re: AC water pump/ strainer and valve location ?
Posted: August 25th, 2023, 11:18 am
by dtcom
REPOSE wrote:QR_BBPOST Just put my new to me Carver 2827 Voyager in the slip yesterday , having trouble finding the thru hull connection and pump. There is no water flow through the unit and there for is not cooling. Thank you in advance for your help.
I don't know if this helps, but I have a Mariner 330. The thru hull is just outside the head, starboard side. There are 2 hatches outside the head to remove.
The filter on mine is a glass canister on the port side. Every time I have put the boat in, the filter needs to be cleaned.
Do you hear the pump running?
Posted: August 25th, 2023, 11:59 am
Welcome to the forum.....where is your AC unit located on that boat ?
