Props
joeslenzak@gmail.com
Props
Postby joeslenzak@gmail.com » February 24th, 2025, 5:41 pm
Hi - I'm new to the Carver Forum.
I have a 2002 410 Sport Sedan. The props were changed out at some point by the original owner. It has twin Cummins diesels (370 hp). It struggles to get on plane unless I turn the steering wheel and then it seems break free and come onto plane. Current props are 24x29. I am trying to find out what the original props were on this boat. I think the replacement prop pitch may be too much.
Been thanked: 262 times
Re: Props
Postby buster53 » February 25th, 2025, 12:15 am
You may be over propped. What is your WOT RPM and what is the engine mfg’s recommended max RPM? We need the answer to those 2 questions before any recommendations can be made.
Has thanked: 583 times
Been thanked: 1225 times
Re: Props
Postby bud37 » February 25th, 2025, 8:27 am
Welcome to the forum...... to add to the above,....maybe you have but, make sure your trim tabs are working as they should and bottom is not fouled.
Re: Props
Postby bud37 » February 25th, 2025, 4:20 pm
One other add....have you got any black smoke from one engine or both ?....see that thing about turning the wheel is interesting. On the sea trial was all ok ?
There are a few things to cross off before the prop consideration.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 119 times
Been thanked: 119 times
Re: Props
Postby KyleR » February 27th, 2025, 3:22 pm
We have a 2002 396 with the twin Cummins 6bta 370HP diesels too. I found the original delivery paperwork when we bought our boat and it came standard with 24x29 props. I know it's not the same boat as yours, but very similar and of the same vintage. The delivery paperwork said it hit 3050rpm on the water at delivery.
However, that was for an empty boat with probably not a lot of fuel or water and no personal items. When we bought the boat in 2022 it would only make 2700rpm ar WOT with a clean bottom and none of our "stuff". After two years and fully loaded with a not-so-clean bottom, it only made 2400 rpm at WOT. Obviously WAY overloaded so we basically ran it like a trawler for the last year+ to keep the engine from working so hard.
We just launched today after a month in the yard and now have a very clean bottom and we swapped out the props out for 24×25.5, so we'll see what happens. We're staying on anchor for a few days to chill out and recover but I'll post back once we run it up.
Anyway, long story short, you definitely sound overpropped. Those engines should be able to spin at 3100-3150rpm, under load, at WOT. ;-)
Kyle
MV Verity
2002 Carver 396
Re: Props
Postby joeslenzak@gmail.com » February 28th, 2025, 12:41 pm
Thanks Kyle for the info. I don't have the WOT RPM, but I know it will do at least 2800. My typical running speed is 2400 rpm @ approx 19-29 mph. Bottom is clean
Let me know how the new props perform
Joe
KyleR
2002 Carver 396
Re: Props
Postby KyleR » March 2nd, 2025, 5:02 pm
So my first round numbers were 2995rpm on port, 3050rpm on starboard, at WOT. This was with 24x25.5 props, freshly serviced aftercoolers/heat exchangers (per Seaboard method), freshly sanded/painted bottom, 12-15mph cross winds, light chop in the water, in 20-25ft deep water, and the boat weighing in right at 37,000lbs (per the boatyard travel lift scale). I really think on flat water with calm winds I will be able to hit the recommended 3100-3150rpm. This is the best these engines have run since we bought the boat so I'm pretty pleased.
One other thing I noticed was that my throttle levers at the helm were pegged against the dash, so there may have still been additional throttle movement available at the engine if I tweak the cable mounts. I'll be exploring over the next week or so.
MV Verity
2002 Carver 396
Users browsing this forum: No registered users and 64 guests
