My fuel transfer pump is leaking when turn on to transfer from one tank to another.
1998 Carver 4808 . Can this be repaired or replaced?..
Fuel transfer pump
- Been thanked: 1794 times
Re: Fuel transfer pump
Ya it's pretty common for those pumps to leak. Yes you can replace the pump, they're readily available online or your local marine supply store. I'm sure you can source a replacement seal too if you want to go that route but considering you're dealing with fuel, it's best to replace the pump.
