Fuel transfer pump
Posted: May 16th, 2026, 3:32 pm
by Preferred
My fuel transfer pump is leaking when turn on to transfer from one tank to another.
1998 Carver 4808 . Can this be repaired or replaced?..
Re: Fuel transfer pump
Posted: May 16th, 2026, 3:34 pm
by Preferred
455 carver diesel engine
Posted: May 16th, 2026, 11:50 pm
Ya it's pretty common for those pumps to leak. Yes you can replace the pump, they're readily available online or your local marine supply store. I'm sure you can source a replacement seal too if you want to go that route but considering you're dealing with fuel, it's best to replace the pump.
Posted: May 17th, 2026, 8:14 am
by Preferred
Thank you, I have never had to deal with this issue.
