2006 Carver 38SS AC compressor & pcb
Topic author Great Britain
Peter
Vessel Info: Carver 38ss 2007
Has thanked: 23 times
Been thanked: 7 times
Postby Peter » June 23rd, 2018, 3:25 pm
Hi Guys
Wheres best place for me to get a new compressor & pcb please.
Thanks Peter
Been thanked: 615 times
Re: 2006 Carver 38SS AC compressor & pcb
Postby g36 » June 24th, 2018, 8:57 am
Hi need some more info. What kind of ac and model of ac? Age? What's the issue?
Most likely won't be worth replacing compressor or pcb be better to replace with new unit and have a warranty. But hard to say without some more info.
Peter
Postby Peter » June 26th, 2018, 4:02 pm
Its a Dometic vector compact in a 2006 Carver 38ss
115v 60hz
Serial number 60378701
VCD16K/2
205-311700
16000btu
Hope that helps
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » June 26th, 2018, 4:38 pm
If the compressor failed electrically (shorted to ground) you are better off replacing the complete unit. The acid created by burnt oil and refrigerant residue from the failed compressor will significantly shorten the life of the new compressor. Its not cost effective to attempt to clean up such a small system.
Peter
Postby Peter » June 27th, 2018, 2:09 am
Ok but do you know where best to get the unit please
Postby g36 » June 27th, 2018, 10:06 am
would be curious what your symptom is with yours. replacement unit thats going to bring out some different ideas of whats best. probably get lots of suggestions on what to get. i've purchased these for different boats currently have 2 on mine now. i like mermaid manufacturing ac units they have a 5 year warranty use more common parts than some companies no specialty control pcb depending on the thermostat you choose. post warranty repair can be done by a general hvac tech doesnt have to be a boat hvac tech. marinewholesalers has good pricing on them.
https://www.mmair.com/marine-division/m ... ditioning/
Has thanked: 269 times
Been thanked: 1153 times
Postby Midnightsun » June 27th, 2018, 1:46 pm
As mentioned you will get a lot of recommendations. Here is mine. https://www.marinaire.com/Marine-air-co ... ba16k2.htm
Peter
Postby Peter » June 28th, 2018, 1:52 pm
The marine air looks good but ideally i like to use my IMP wall controllers
Can they still be used ?
Postby tomschauer » June 28th, 2018, 11:10 pm
A new unit should come with a new controller. After 12 years, even if you by the same brand you have, there is a good chance your existing controller will not be compatible.
Users browsing this forum: No registered users and 43 guests
