V Berth Lights
Zarko48
Vessel Info: 1997 350 Mariner Crusader 5.7 XLs 6.5 Kohler
Has thanked: 6 times
V Berth Lights
Post by Zarko48 »
The two pivoting LED lights in the V berth over the bed are not working. Checked with a volt meter and there's no power going to them? Any one have a wiring diagram, or secret power switch location? The other pot lights in the room work fine?
Dave in the beautiful 1000 Islands.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: V Berth Lights
Post by buster53 »
is this something new or have they always not worked?
Check your circuit breakers?
Any chance these 2 lights are 120v and you're either not plugged into shore power or the appropriate circuit breaker is off?
Has thanked: 605 times
Been thanked: 1313 times
Re: V Berth Lights
Any chance those lights have a separate on /off right on them.....that is what ours are like.....maybe some corrosion.....
buster53
Re: V Berth Lights
Post by buster53 »
bud37 wrote:QR_BBPOST Any chance those lights have a separate on /off right on them.....that is what ours are like.....maybe some corrosion.....
I've had lights that had both switches on the fixture and a wall mount switch. Obviously, both have to be turned on
Zarko48
Re: V Berth Lights
Post by Zarko48 »
Yes they do have a separate switch but I've removed the light(s) and checked for power before the switch with and without the other light switch on.
Zarko48
Re: V Berth Lights
Post by Zarko48 »
buster53 wrote:QR_BBPOST is this something new or have they always not worked?
They didn't work during the survey - 1 1/2 years ago. They are LEDs so certainly 12V. The wiring diagram is only a schematic so does show any detail and/where wiring runs from or to?
Zarko48
Re: V Berth Lights
Post by Zarko48 »
Opps schematic does NOT show detail.
