V Berth Lights
Zarko48
Vessel Info: 1997 350 Mariner Crusader 5.7 XLs 6.5 Kohler
Has thanked: 6 times
V Berth Lights
Postby Zarko48 » June 9th, 2019, 12:20 pm
The two pivoting LED lights in the V berth over the bed are not working. Checked with a volt meter and there's no power going to them? Any one have a wiring diagram, or secret power switch location? The other pot lights in the room work fine?
Dave in the beautiful 1000 Islands.
buster53
Vessel Info: 2001, Carver 356
Been thanked: 261 times
Re: V Berth Lights
Postby buster53 » June 9th, 2019, 12:29 pm
is this something new or have they always not worked?
Check your circuit breakers?
Any chance these 2 lights are 120v and you're either not plugged into shore power or the appropriate circuit breaker is off?
Has thanked: 579 times
Been thanked: 1210 times
Re: V Berth Lights
Postby bud37 » June 9th, 2019, 12:37 pm
Any chance those lights have a separate on /off right on them.....that is what ours are like.....maybe some corrosion.....
buster53
Re: V Berth Lights
Postby buster53 » June 9th, 2019, 1:31 pm
bud37 wrote:Source of the post Any chance those lights have a separate on /off right on them.....that is what ours are like.....maybe some corrosion.....
I've had lights that had both switches on the fixture and a wall mount switch. Obviously, both have to be turned on
Zarko48
Re: V Berth Lights
Postby Zarko48 » June 12th, 2019, 9:47 am
Yes they do have a separate switch but I've removed the light(s) and checked for power before the switch with and without the other light switch on.
Zarko48
Re: V Berth Lights
Postby Zarko48 » June 12th, 2019, 9:53 am
buster53 wrote:Source of the post is this something new or have they always not worked?
They didn't work during the survey - 1 1/2 years ago. They are LEDs so certainly 12V. The wiring diagram is only a schematic so does show any detail and/where wiring runs from or to?
Zarko48
Re: V Berth Lights
Postby Zarko48 » June 12th, 2019, 9:54 am
Opps schematic does NOT show detail.
Return to “Electrical”
Users browsing this forum: No registered users and 88 guests
