Circuit breaker search
Mrbigler
Vessel Info: 1987 3207 Aft Cabin with Kohler 7.5R27 generator
Been thanked: 3 times
Post by Mrbigler »
Ok folks I need some help. I have a 1987 3207 with dual 30amp shore power connectors. They lead to 2 separate 110volt AC buses, each protected by a separate main breaker (pictured below), one has gone bad. Anyone have any idea on a source for these.
Been thanked: 470 times
Re: Circuit breaker search
Post by RGrew176 »
I would think that any marine supplier would be able to order it if they don't have it in stock.
Hope this is helpful.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 415 times
Post by Cooler »
Yep, Rick is right. Common part. Bring it with you to a marine store and they should have in stock. May not be a switch type, some are push button, but that will not matter. Make sure you inform the seller it is a marine application. Anti-corrosion built in. 8-) er
Cooler By The Lake
Has thanked: 605 times
Been thanked: 1313 times
Like has been said.....to add, search the airpax part number to see what comes up....amazon/e bay. You can get Blue sea replacements....check their site for a match then check amazon, these are common.....good luck on your search... :down:
