Circuit breaker search
- Mrbigler
- Vessel Info: 1987 3207 Aft Cabin with Kohler 7.5R27 generator
- Been thanked: 3 times
Ok folks I need some help. I have a 1987 3207 with dual 30amp shore power connectors. They lead to 2 separate 110volt AC buses, each protected by a separate main breaker (pictured below), one has gone bad. Anyone have any idea on a source for these.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Circuit breaker search
I would think that any marine supplier would be able to order it if they don't have it in stock.
Hope this is helpful.
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Yep, Rick is right. Common part. Bring it with you to a marine store and they should have in stock. May not be a switch type, some are push button, but that will not matter. Make sure you inform the seller it is a marine application. Anti-corrosion built in.
er
erCooler By The Lake
Like has been said.....to add, search the airpax part number to see what comes up....amazon/e bay. You can get Blue sea replacements....check their site for a match then check amazon, these are common.....good luck on your search...
