New
- Ray.spahn
- Vessel Info: 1987 32' Mariner Carver
New
1987 32' carver - Glad to be here. The reason I'm here trying to find out how to access the A/C unit. My understanding it is under the sink area - but can not find out how to access it. Thanks
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: New
Best answer I can give you…where is your air return? Chances are real good the unit will be within a couple feet, if not directly behind it.
With any new boat, get a good flashlight, open every hatch, open doors, look under mattresses, etc. Carver has a real good habit of hiding openings.
Find all through hulls, bilge pumps, sump pumps….identify hoses and what their purpose is. Find your onboard water system water pump as there is a real good chance you will be replacing it at some point.
- Been thanked: 1114 times
Re: New
Welcome aboard!!
Posting up some pictures of your situation always helps folks visualize what you're dealing with. It might also help folks who used to have that model or a similar model remember where things are at.
- Been thanked: 493 times
Re: New
Welcome aboard!
- RGrew176
- Vessel Info: 2025 Godfrey Xperience 2286 SFLX
- Has thanked: 72 times
- Been thanked: 470 times
Re: New
Welcome Aboard.
- Ray.spahn
Re: New
Found the A/C unit - Luckily all it was is a switch that was tripped for not having any water running through the a/c (it works). But good luck if it needs to be serviced there is no way I can see you can get to the unit without tearing out cabinets or seats. Thanks for the input, appreciated.
