New
Ray.spahn
Vessel Info: 1987 32' Mariner Carver
New
Post by Ray.spahn »
1987 32' carver - Glad to be here. The reason I'm here trying to find out how to access the A/C unit. My understanding it is under the sink area - but can not find out how to access it. Thanks
Been thanked: 285 times
Re: New
Post by buster53 »
Best answer I can give you…where is your air return? Chances are real good the unit will be within a couple feet, if not directly behind it.
With any new boat, get a good flashlight, open every hatch, open doors, look under mattresses, etc. Carver has a real good habit of hiding openings.
Find all through hulls, bilge pumps, sump pumps….identify hoses and what their purpose is. Find your onboard water system water pump as there is a real good chance you will be replacing it at some point.
Re: New
Welcome aboard!!
Posting up some pictures of your situation always helps folks visualize what you're dealing with. It might also help folks who used to have that model or a similar model remember where things are at.
Been thanked: 492 times
Re: New
Post by waybomb »
Welcome aboard!
Re: New
Post by RGrew176 »
Welcome Aboard.
Re: New
Post by buster53 »
Did you ever find it?
Ray.spahn
Re: New
Post by Ray.spahn »
Found the A/C unit - Luckily all it was is a switch that was tripped for not having any water running through the a/c (it works). But good luck if it needs to be serviced there is no way I can see you can get to the unit without tearing out cabinets or seats. Thanks for the input, appreciated.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Re: New
Post by pepmyster »
Welcome!!!!!!!!!!!!!
Re: New
Post by g36 »
Welcome aboard
