506 wiring run from engine room to bridge
kurt404
Post by kurt404 »
Hi,
I have a 506 and need to run a cable from the engine room to the bridge helm. I see the wires going through the access hole on the starboard side under the helm console but unsure of the route and where they come out in the engine room. Any help is appreciated.
Thanks!
Has thanked: 70 times
Been thanked: 493 times
Re: 506 wiring run from engine room to bridge
Post by waybomb »
I can't help you with your question, but when you do figure it out, run an extra wire so next time you can simply pull whatever you are running with that extra wire.
Tennessee River Rat
Vessel Info: 2001 Carver 506 Aft Cabin 480 Volvo's
2007 Meridian 341 with 6.2 MPI Horizon Mercruiser Engines
1988 Sea Ray 340 with Twin 454's
1987 Stratos with 200 HP Merc
Has thanked: 3 times
Been thanked: 6 times
Post by Tennessee River Rat »
There is a seat on the starboard side of the fly bridge that has a removable panel under the cushion. There will be two posts, which are the battery posts from below and wiring for other items. Also, there is an access panel on the starboard side of the stairs. Hope that helps.
kurt404
Post by kurt404 »
I found that the easiest way to run a wire from bridge to engine compartment was in the salon a/c area. Just pull the return grill and you will see many wires including the throttle/shift cables on the right side.
