Rear Sliding Cabin Door
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 23 times
Re: Rear Sliding Cabin Door
- Gag_Halfront
- Vessel Info: 1990 Carver Mariner 3297
- Been thanked: 20 times
- thatchh
- Vessel Info: 2004 Carver 396ES gas Crusader 8.1
- Been thanked: 10 times
- tgebler
- tgebler
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
I ended up cleaning the upper and lower tracks really well with some old paint brushes, blue shop towels, and degreaser. It was amazing what came out of there. Sand, dirt, old grease, etc... Then I used a product called Slipit. https://www.slipit.com/all-products/sf-sliding-compound/ on the tracks. A liberal dose on the upper and lower really did the trick. Now my kids can open the door easily. Worked well on a couple sticky windows I had also.
- Vessel Info: 1989 Carver 3467 Santego
- Has thanked: 17 times
- Has thanked: 324 times
- Been thanked: 595 times
You would think (as I did) adding some lubricant will help. It does, for a very short time, then is helps "hold" the dust and dirt in the track and actually makes it worse.
Clean the tracks constantly, both upper and lower, and just use a dry silicone spray.
Users browsing this forum: No registered users and 66 guests
