Rear Sliding Cabin Door
tgebler
Vessel Info: 2000 396 AC
Has thanked: 5 times
Been thanked: 23 times
Re: Rear Sliding Cabin Door
Postby tgebler » January 30th, 2021, 11:09 am
My door is different from what you depict in your post.
This photo shows the door in the lower left and the handle on the outside. There is no handle on the inside just a finger hole.
Gag_Halfront
Vessel Info: 1990 Carver Mariner 3297
Been thanked: 20 times
Postby Gag_Halfront » January 30th, 2021, 12:46 pm
Oh! I'm sorry. I misunderstood. That's certainly very different from the glass doors on other models. Hopefully your picture will jog someone's memory who's done one of these before.
thatchh
Vessel Info: 2004 Carver 396ES gas Crusader 8.1
Been thanked: 10 times
Postby thatchh » February 19th, 2021, 5:10 am
I also have the 396 with that door I have not determined a way to remove the rollers. Mine have gotten flat sided, but the door still slides pretty well when I spray it with silicone lube. About once a month keeps it sliding ok. I agree about the handle. You might have to use one that attaches with screws, or one the has the built in bolts and live with nuts on the outside. Maybe you could cover them with rubber caps. This is on my list to address, but it's not near the top yet.
tgebler
Postby tgebler » February 19th, 2021, 9:36 am
Someone susggested a handle which is normally used in the at-home shower which attaches with suction. I have ordered one and will give it a try next week. If it doesn't work, I can always drill a couple of holes and attach a permanent handle. If I go that route, I have decided to take off the outer handle and put the screw heads behind that handle. I will keep everyone posted and include pics of which ever method works best.
tgebler
Postby tgebler » February 24th, 2021, 3:19 pm
I bought and today installed the handle which was recommended by tomschauer. I works very well and I am pleased with this solution. Another plus for the forum.
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 75 times
Postby chpsk8 » February 24th, 2021, 4:39 pm
I have a 355 aft and my door didn't slide well at all. The PO put one of those suction cup shower handles on it, but it would fall off occasionally and was a general PITA after awhile.
I ended up cleaning the upper and lower tracks really well with some old paint brushes, blue shop towels, and degreaser. It was amazing what came out of there. Sand, dirt, old grease, etc... Then I used a product called Slipit. https://www.slipit.com/all-products/sf-sliding-compound/ on the tracks. A liberal dose on the upper and lower really did the trick. Now my kids can open the door easily. Worked well on a couple sticky windows I had also.
MichaelOKC
Vessel Info: 1989 Carver 3467 Santego
Has thanked: 17 times
Postby MichaelOKC » April 27th, 2021, 7:44 pm
Upon your recommendation, I just ordered a pint of Slipit and should receive delivery in a day or two. Thanks for your advice.
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » April 27th, 2021, 11:25 pm
Keeping the tracks clean is key.
You would think (as I did) adding some lubricant will help. It does, for a very short time, then is helps "hold" the dust and dirt in the track and actually makes it worse.
Clean the tracks constantly, both upper and lower, and just use a dry silicone spray.
Users browsing this forum: Notsooowicked and 139 guests
