The "buttons" on the console for controlling trim are either frozen or never had any good feedback. What alternatives are there without modifying the panel? If modifying the panel, what are good robust weatherproof options?
Thanks!
Replacement Switches for Trim Controls
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
Fun times on the 1988 Carver Santego 30
- Been thanked: 1313 times
Re: Replacement Switches for Trim Controls
Which buttons don't work....the engine drive trim buttons or the trim tab buttons ?
- Been thanked: 654 times
I would remove the screws to the panel to gain access to the switches. Once you can see the back of them it shouldn't be to difficult to cross these to new push button switches. There may be some numbers on the body of the switch to help id or you can just measure the mounting hole and find new ones that will fit and have the same switch action.
- Been thanked: 1114 times
If it's the trim tab switches you're talking about... I'd bet those are the standard Bennett switches mounted under that panel. They are not separate switches, but a module with four switches integrated. I know I have one of those around here somewhere from when I upgraded to the rockers, but I don't know where it is or I'd post some pics and look at it to see if it could be cleaned.
- theorifice
Thanks! Do you have a suggestion for a suitable rocker replacement?
