Repair wall covering
tgebler
Vessel Info: 2000 Carver 396 AC
Has thanked: 5 times
Been thanked: 29 times
Post by tgebler »
I have a 2000 396 aft cabin. Some of the vinyl wall covering is sagging (best description I can provide). Has anyone dealt with this issue and, if so, how did you fix it. Is it possible to fix the sags without replacing the wall covering? I should point out that I have limited skills. I guess I should have gotten vocational training instead of law school!!
Hold'n On II
Vessel Info: New to us 1996 370 Voyager
Been thanked: 11 times
Re: Repair wall covering
Post by Hold'n On II »
Depends on where the "sags" are. Sometimes, you can remove the trim above or to the side of the area to locate & remove staples then re-stretch the fabric and re-staple. My guess is there's something else going on to cause the foam backed vinyl to de-laminate in the first place.
