Magnetic switches
mjmason1
Vessel Info: 1999 Carver Voyager 530
Has thanked: 2 times
Been thanked: 19 times
Magnetic switches
Post by mjmason1 »
Does anyone know what these magnetic switches actually do. One of my port side ones are burnt.
Been thanked: 1114 times
Re: Magnetic switches
What engines do you have?
Could they (or one of them) be for the glow plugs?
Sgodfrey
Vessel Info: Carver 450 Voyager
Been thanked: 9 times
Post by Sgodfrey »
Looks like you have Cummins 6cta engines. Sbmar.com seaboard marine is the place to get help on the engines. They have the electrical diagram on their site.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 154 times
Been thanked: 149 times
Post by KyleR »
I'm guess you have three switches per engine? Two are for the aftercooler air heaters and one is for the main engine starter, if I remember correctly.
My aftercooler ones were burnt up also so I pulled the aftercooler heater fuse to disable the whole system - it looked like it was a fire waiting to happen! After running the boat for 6 months with no discernable difference, I removed the entire system (mag switches, wiring harness, etc) which just cleaned up the whole area of the engine a lot!
Now if you are up north and routinely run the boat in the winter, that heater definitely helps with starts! But an oil pan heater will do the same with a lot less wiring. Since we stay away from the cold I have found no impact removing the system.
As mentioned, a lot about this can be found on the SeaBoard Marine website which is where I found out about disabling/removing the system if it is unnecessary. YMMV. ;-)
MV Verity
2002 Carver 396
