Waste and Water fill cap replacements
goingjag
Vessel Info: 1988 Voyager 28
Post by goingjag »
New to me 1988 28' Mariner Voyager. 1 owner boat.
He lost the waste and water caps. The replacements he has are a water one that is too small, and a waste one that is too big.
I've searched this forum as well as around the net, Perko and Attwood sites.
I measured the inside diameter of the deck fittings with a micrometer with the waste coming in at 1.749 - 44.38 mm and the water at 1.769 inches 44.98mm.
I suspect the one that is too big is just the wrong thread size, as there are 1-3/4 inch ones out there (rare but there). It had been cranked partly into place but required large water pump pliers to remove I found mention of Atwood as having an odd thread, but found nothing on their site 1-3/4". On eBay I found a 1-3/4 for a Perko speced as fitting a much larger Carver than mine.
Any thoughts would be appreciated. Thanks.
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Waste and Water fill cap replacements
Post by Lyndon670 »
Take them out and add new asseblies...simple. Just use Sikaflex or 3M sealant when you reinstall. Much easier than messing around trying to match a cap.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
goingjag
Post by goingjag »
Thanks Lyndon sounds like a plan given lack of info/availability of the right ones. Hopefully there is enough hose under the deck that I can pull them out and install from above the deck.
