Carver 405 owner new guy
405driver
Vessel Info: 1998 Carver 405 gas
Has thanked: 37 times
Been thanked: 6 times
Re: Carver 405 owner new guy
Post by 405driver »
I have Velvet drives model number 20-01-005. My starboard drive is noisy. Nothing in neutral, but forward and reverse seem to make some noise. I guess I should start with the engine making sure its running on all cylinders, then if that checks out, change the fluid. If that dosen't fix maybe bore scope the inspection plate on the top of the drive. Anyone have any more ideas?
Those are all good things to check. What engines do you have? You also want to ensure RPM isn't too low. Also possible flex plate.
Carver370
Vessel Info: 1994 Carver 370
Post by Carver370 »
Fyi the material use for the aft deck dodger board is Cyro Acrylite and is still available.
