Last season, I scraped off all the existing non-skid and took every thing back to the gel coat. Then painted with an oil base, exterior grade industrial paint, recommended by a local repair guy. We then added non-slip crystals to the paint and rolled on a second coat.
Long story short, the resulting finish is not acceptable. The non-skid is not even, with the grit heavy in some areas and light in other areas. I tried to ensure even coverage, but I was not successful. On the plus side, the deck was definitely non-skid, but it looks bad.
I am looking at re-doing the work this spring, scrape it down again and then re-do the non-skid. I am looking for suggestions as to which product to use and any recommendations for application. I don't mind paying for the right product, as long as it is not gold plated...
How about it, can you help?
