We need to replace a couple circuit breakers, the main breaker for accessories and pumps. Panel is 12VDC Any idea where we can purchase from?Circuit breakers on 1987 42 aft
- The Dash
- Vessel Info: 1987 Carver 42Aft Cabin
- Has thanked: 3 times
We need to replace a couple circuit breakers, the main breaker for accessories and pumps. Panel is 12VDC Any idea where we can purchase from?- waybomb
- Been thanked: 492 times
Re: Circuit breakers on 1987 42 aft
Whenever I needed one when I was i Wisconsin I'd be going to Kendor's in Franklin Wisconsin. They have an Ebay presence as Greatlakesskipper.
They buy a lot of surplus from Carver, Cruisers, and others, along with selling new stuff.
Give them a call with a description.
My 4207 also had a light for each breaker. Those would go bad and they had those as well.
West Marine, and most any marine supply store should have them. A camper/ RV store may have them cheaper?
- Been thanked: 1312 times
Try Blue Seas Systems, big assortment of marine electrical ........
Someone can probably confirm but it's likely Carling breaker. Try this link and scroll down to the breaker section and series that matches what you have. As mentioned above, any marine retailer should be able to get what you want. There should be a label on the side of the breaker with the specs needed to order the proper replacement.
http://www.carlingtech.com/marine
