Battery Equalization
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 65 times
Postby feeez » March 20th, 2017, 4:52 pm
The new charger that I installed in the boat last season has a equalization feature in it for flooded batteries. I would be interested in some feedback about doing this process how often etc etc. I understand what is going on but have found limited information about it.
Fraser
Former 2001 350 Mariner owner
Been thanked: 1055 times
Re: Battery Equalization
Postby km1125 » March 20th, 2017, 5:54 pm
MAYBE once a month. All depends on how the battery is used. If you do heavy discharges and charges, you don't need to do it at all.
Its real value is for those batteries that sit at nearly full charge all the time, or have small loads for a while and then get recharged slowly.
Has thanked: 458 times
Been thanked: 1699 times
Postby Viper » March 21st, 2017, 7:58 pm
I agree.
Fraser, check the manual. I don't recall if the PronauticP does but some chargers I've installed will do it automatically once certain criteria are met.
You want to check your electrolyte levels before and after you equalize. Because of the voltages involved; 15-16 volts, you should turn off power to all 12 volt loads during equalization, as some may not handle it very well.
feeez
Postby feeez » March 22nd, 2017, 1:25 pm
I checked the manual and it i not automatic.
Thanks for the input gents!!!
Cheers
Fraser
Return to “Electrical”
