Newbie here
06carp
Has thanked: 4 times
Newbie here
Post by 06carp »
:captain: Got rid of 20ft HydroStream Blue Printed 2.4 Bridgeport 110hp nitrous wanting to replace it with a Aft Cabin Carver, thinking about a 3207 or 32ft aft cabin.
Got on here to find best option I understand some Carvers have Dual Hulls ( trawler at 7-8 knots planning at 25 )
Hope to be proud owner of a Carver soon.
Re: Newby here
Welcome to the neighborhood. That's quite the change of pace! Good luck with your search.
Been thanked: 492 times
Re: Newby here
Post by waybomb »
Let us know what you buy!
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Newbie here
Post by Lyndon670 »
I think you are misreading some posts. All of our boats are planning hulls, not displacement hulls like a conventional trawler. But, they are all very "economical" to operate at HULL SPEED - 6-8kts.
Welcome to the jungle!
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Been thanked: 470 times
Re: Newbie here
Post by RGrew176 »
I was reading somewhere online last week that running a planeing hull boat at slow hull speeds is hard on the transmission. It may only be a coincidence but last season I made a hull speed run from my home port to Middle Bass Island. It was about a 4 hour trip. It was economical fuel usage wise. It was the next day when my port side transmission clutches fused. Fortunately it was stuck in forward so I could use the port engine travelling forward.
I wonder if running that slow could have caused my problem.
Re: Newbie here
RGrew176 wrote:Qr Bbpost I was reading somewhere online last week that running a planeing hull boat at slow hull speeds is hard on the transmission. It may only be a coincidence but last season I made a hull speed run from my home port to Middle Bass Island. It was about a 4 hour trip. It was economical fuel usage wise. It was the next day when my port side transmission clutches fused. Fortunately it was stuck in forward so I could use the port engine travelling forward.
Rick, I honestly don't think so, lots of us run that way for years on and off...how would anyone do the loop ( canals ) if that was true......there is a formula for calculating your particular hull speed.
Been thanked: 1114 times
Re: Newbie here
06carp wrote:Got on here to find best option I understand some Carvers have Dual Hulls ( trawler at 7-8 knots planing at 25 )
I don't know if it applies to all, but mine will stay on plane down to about 12 kts, which is also very economical and gives a nice ride.
I can't imagine that this would be an issue unless there was already leakage (internally, losing pressure on the clutch) in the transmission, so at lower engine RPMs and higher torque the transmission was slipping constantly. Above 1000 RPMs or so that transmission should be locked in gear with no slip.
06carp
Re: Newbie here
Post by 06carp »
I realize Carvers aren't Displacement Hulls but if I'm not in a hurry why not save some gas. Does anyone know what models are more efficient at slower cruise speeds.
Re: Newbie here
06carp wrote:Qr Bbpost I realize Carvers aren't Displacement Hulls but if I'm not in a hurry why not save some gas. Does anyone know what models are more efficient at slower cruise speeds.
I don't know if I'd use that as a criteria unless you were strictly looking at displacement hulls and long distance. Other features of the boat are going to make a lot more difference (loading, EFI, bottom paint, thru-hulls, tabs, etc).
Look for the layout and style you really want, then differentiate on engines and drives and other features.
06carp
Re: Newbie here
Post by 06carp »
I'd rather be living on a trawler on the Gulf Coast but wife says no way. I'll be putting boat on Tablerock Lake in MO, I researched different brands and the options Carver has looks like it will suit my needs best. Be retired and in no hurry ( already did the go fast thing ).
