Installing Flooring in Carver Mariner
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Re: Installing Flooring in Carver Mariner
Post by SanJuanDreamer »
Bryon857, the floor space just in front of the dinette table, did you see anything that might explain why the floor moves a little?
Bryon857
Vessel Info: 2002 carver 350 mariner
Has thanked: 2 times
Been thanked: 13 times
Post by Bryon857 »
This may be what you are asking. There is a 3/4 inch plywood across the middle of the boat. It has some aluminum crossmembers for support. Mine has a little give also, added the 1/2 engineered wood on top of it, seems to help some.
SanJuanDreamer
Ah, good idea..
Bryon857
Post by Bryon857 »
Still working, out of flooring trying to order some more. Use 3 boxes about a 100 sq ft., not a lot of waste.
Randymccann
Vessel Info: 1986 32ft carver mariner
Has thanked: 6 times
Post by Randymccann »
Just got done having mine done was vynl planking that looks like wood. Had to be glued down.
prowler1k
Vessel Info: 2002 Carver 396 Aft Cabin
Post by prowler1k »
Looks great and gives us an idea of what is in store! Recently purchased a 2002 396 and going to use the snap on laminate flooring from Lowes. Still exploring details...what are your plans for the stairs?
Thanks for sharing your experience!
Bryon857
Post by Bryon857 »
Still at it
cpoint
Has thanked: 208 times
Been thanked: 32 times
Post by cpoint »
looks great, you done a fantastic job. i am nearly done with mine....
SanJuanDreamer
Wow...just amazing!!!! Ok, you can do mine next?
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Post by amanphoto »
Awsome!!! Great shots.
