Potable water tank monitor meter??
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Need help locating the meter for the potable water tank. Documents says the boat has one, I see the wiring coming from the water tank, just can't find the meter? Help again!
Dan
Dan
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- justavacation
- Vessel Info: 2000 Carver 406 w/cummins 370hp
- Has thanked: 2 times
Re: Potable water tank monitor meter??
Hi, I have a 2000 406 and my water tank monitor is in the rear head next to the light/fan/head switches. Just under the counter top.
- Been thanked: 654 times
yep thats where it is on my 405 i also have a breaker in the main electrical panel for it
- dsolo
454 EFI Crusaders
So I thought that was the waste tank monitor. OK thanks.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
The waste monitor tank watch is the 3 or 4 lights panel the water monitor is a at leat oem round guage in the same vicinity . I almost hesitate to say after the inverter
Take a look at this pic the water guage us on the far right below the counter top by the head
https://www.google.com/search?q=carver+ ... VrXRnwaCYM:
- mjk1040
- Been thanked: 248 times
Hmm! On the 355 model it's in the galley, right of the stove, wonder why the put it back there on the 405's?
Mike
- dsolo
454 EFI Crusaders
Thanks to all. I will check it out this weekend. I plan on sanitizing the water system, per the method I read here, and using the water from the tank exclusively. The water monitor will be a valuable tool.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
Well found the meter right where g36 stated. Unfortunately it is not registering the tank level. It show's empty and the tank is full. Today while working on another problem I noticed alot of crosion on the wire terminals at the tank. I will clean them to see if it corrects the problem??
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Been thanked: 1312 times
dsolo wrote:Qr Bbpost Well found the meter right where g36 stated. Unfortunately it is not registering the tank level. It show's empty and the tank is full. Today while working on another problem I noticed alot of crosion on the wire terminals at the tank. I will clean them to see if it corrects the problem??
Have a close look at the terminals on the tank, see if there are two small adjusting screws on the plate, if so then you can adjust the tank gage reading with those..full and mt..instructions would be in owners manual....I know ours has that, but have a look.......
- dsolo
454 EFI Crusaders
Following up on this post. Found the terminals heavily corroded. Scrapped and cleaned with contact cleaner. Adjusted the two pots back and forth. Had no effect on meter. Measured+12 vdc on power terminal and +8 vdc on other terminal. Adjusting pots did not vary voltage (+8vdc)
Does any know the mfg'r of this unit? Thanks
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
