Main Front Window Weather Stripping Repalcement
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Main Front Window Weather Stripping Repalcement
- Vessel Info: 1998 Carver 350 Mariner
- Has thanked: 22 times
bud37 wrote:Source of the post You can call Carver Yachts, parts with your hull # , explain the part to Pat and see what they have, maybe they can give you a part number for whoever made it in the first place. Actually on the Carver Yachts website, under owners is a drop down box with some choices, manuals ,parts and such......just follow thru with your year and model and pick thru it....lots of info...I just did the same for my windshield screw covers that had shrunk like crazy........
By wndshield screw covers are you referring to the black foam strip at the base of the windshield? If yes, mine is also shrinking and I suspect that it may be the source of rain water pooling on the dashboard. I obtained a piece of black foam pipe insulation, cut it to fit the space and inserted. Look good from a distance. If the rain water is comming from the gaps, hopefully this fix will take care of the problem. Supposed to rain this weekend so I'll find out.
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
That was last year, already went through winter and still looks good.
My first try was using a more stiff insulation, it didn't look right and it didn't last long, so I used a softer insulation...
SanJuanDreamer wrote:Source of the post I did the same, bought pipe insulation from HomeDepot, cut replaced what was there.
Prior to replacing, did you have pooling of water on dashboard after a moderate to heavy rain?
- SanJuanDreamer
Since replacing the foam, I cant recall seeing it pool again.
Good idea to pull the screws and reseal.
- Finest
- Vessel Info: 1997 Mariner 350
Twin 350 Crusader Engines - Location: Penetang, Georgian Bay
bud37 wrote:Source of the post Yes the screw cover is the one at the base of the windshield on the outside. Actually mine is a sort of plastic ( amazing it could shrink that much, maybe 3" to 4" per side) on the front sections ( each section about 6'), it has a specific shape and is stuck in with two sided tape.....the covers on the sides appear to be some kind of foam, definitely different from the front and have not shrunk.The part numbers are different as well.....I am going to order the correct stuff for the front and clean the channel and remove each screw and reseal them.....we will see.....
I also have the 350 mariner and am having the same problem with water pooling on the dashboard. Do you have the part numbers for the screw cover?
- Finest
- Has thanked: 455 times
- Been thanked: 1671 times
Edit here, I was just not sure of that part number so didn't want to mislead anyone.... Finest...there is an easier way..I have the old I just pulled out and a piece of the new, we can compare to yours for sure......PM me
Taylor was very helpful, they e mailed me the original CAD drawing for the upgraded part so I cut a piece off and compare it to the actual size drawing before I ordered......good luck man.....
