Windlas grease
Topic author
Tomion
Vessel Info: Carver 530
Been thanked: 2 times
Windlas grease
Postby Tomion » June 16th, 2017, 11:28 pm
I recently serviced my Maxwell 1200 windlas. I think I over greased the brass clutch plates as it is not wanting to pull up chain. Does anyone know how much grease should be applied?
Roxanne
Vessel Info: 1999 Carver 356
Has thanked: 13 times
Been thanked: 10 times
Re: Windlas grease
Postby Roxanne » June 17th, 2017, 4:51 pm
Do you have tension on the chain? When I was re-winding ours after we pulled up a tree from the bottom, I know that it just spins around without tension. Once I pulled against it it grabbed and started to wind again
Topic author
Tomion
Re: Windlas grease
Postby Tomion » June 17th, 2017, 10:31 pm
Not much tension even with the tension plate tightened as much as I can get it. Going to put back together with just a smear of grease on clutch cones and hope it works better. I think I had so much grease on cones it would never cinch down tight. When I took it apart it only had a small amount of dried up grease on cones.
Been thanked: 242 times
Re: Windlas grease
Postby mjk1040 » June 18th, 2017, 7:00 am
May I suggest going to the Maxwell site, I believe your model is in the obsolete section. I quick over view of the manual in the maintenance section may answer your questions. I did not see anything about greasing clutch plates?
Roxanne
Re: Windlas grease
Postby Roxanne » June 18th, 2017, 7:35 am
Why is it the stuff that I need help with is in the obsolete section too!! Lol
Topic author
Tomion
Re: Windlas grease
Postby Tomion » June 18th, 2017, 7:52 am
Unfortunately they dont specify how much grease to apply. I read on another websire to use a very thin grease layer, so I will give that a shot.
Re: Windlas grease
Postby mjk1040 » June 18th, 2017, 7:07 pm
I question weather u should grease clutch plates in the first place. I didn't read about applying grease in this area.
Topic author
Tomion
Re: Windlas grease
Postby Tomion » June 19th, 2017, 3:48 pm
This is what maint manual says.
Ensure that the clutches are in good working order by releasing and re-setting them during inspection and wash down. Periodic greasing of the clutch cones with a waterproof marine grease is essential.
Topic author
Tomion
Re: Windlas grease
Postby Tomion » June 23rd, 2017, 11:42 am
After greasing clutch cones hand tighting the windlass was not enough to pull anchor chain up. I removed most of grease leaving behind a very thin coating. The windlass works well now but concerned about the clutch cones with minimal grease on them. I did discover there is a slot to use emergency crank handle to crank down harder on the clutch plates than you can do by hand. I am wondering if I should regrease the cones and then use crank handle to tighten them down?
Re: Windlas grease
Postby mjk1040 » June 24th, 2017, 2:16 pm
Yes the handle is for both purposes. I do not think you can get them tight enough without the wrench. A light coat of good grease should be sufficient.
Users browsing this forum: No registered users and 117 guests
