AaHubb wrote:Source of the post You should probably make sure the replacement batteries are rated as starting/deep cycle. A pure deep cycle battery isn't built to supply starting currents and would not last very long doing so regularly.
..Aaron
I actually think that a deep cycle battery can and will last. My last boat was a Bayliner 3055 Ciera, 1999 model year. When I purchased the boat I had the dealer add 2 additional batteries. I spend quite a few weekends on the hook and I wanted to have the additional power therefore the two additional batteries.
In the spring of 2005 one or two of the batteries had reached the end of their life. I went to Sears and purchased 4 Sears Diehard Deep Cycle Group 27 Marine Batteries and installed them. I sold the boat in 2011 and I still had those same four Sears batteries. They were still going strong. Every spring after the batteries were 3 years old starting with the 2008 season I expected that one or more of the batteries would be finished.
When the 2011 season came, my last season with the boat that spring she fired right up. That is 7 seasons with the same batteries.
Now you get into the question of Cold Cranking Amps. Those batteries were rated at 650 CCA. Now most if not all of us use our boats during the warm months of the year. April to October here. Since we are not starting our boats in cold and sub-zero temperatures just how many CCA's do we really need.
All I am saying is that it is possible that you could install all deep cycle batteries and have no issues. I certainly did not.
Now with my Carver I have what are called Dual Purpose batteries or Deep Cycle and Starting. So far no issues this season with starting or spending time on the hook.
I am not recommending one or the other it is just that in my experience over 7 years I found that Deep Cycle batteries performed flawlessly. And I am in no way trying to say that your assessment is not correct. Your experiences may differ from mine therefore your assessment differs from mine, so please do not take offense at my posting.
