Front Hatch Weatherstripping
byrnewebb
Vessel Info: 1990 Carver 380 Santego
Post by byrnewebb »
I have a 1990 Carver 380 that is leaking around the glass housing and the frame. Prior owners have tried to Silicone the edges where it makes contact with the frame to no avail. I have taken it apart and found that it appears there is weatherstripping on the frame and on the glass. Anyone know where I can get the weatherstripping or if you know of a good fix?
Thank you
My Jurisdiction
Vessel Info: 1981 3007 aft cabin
Has thanked: 19 times
Been thanked: 3 times
Re: Front Hatch Weatherstripping
Post by My Jurisdiction »
I have the same problem on my 3007 1982 aft cabin. I am looking to replace the Hatch cover completely. I have called Carver with no eval, any recommendations.
PluckyCamille
Vessel Info: Mariner 330 1993 St Pete Floreeda
Post by PluckyCamille »
Hi. Did you ever get this fixed? I have a '93 mariner and am having leaking in one of stateroom hatches. Thank you.
Been thanked: 248 times
Post by mjk1040 »
Hatches were most likely Bomar's and most likely you will not find an OEM replacement. Installing a new one will require filling in the old mounting holes and re-drilling for the new mounting screws. The only other thing I can think of as an interim fix is Flex Seal. Flex Seal comes in white, black and clear. And in several different forms. I would most likely try the clear spray Flex Seal to seal the hatch windows. I have no idea what the UV rays will do to Flex Seal over time, but I'm sure you will find out.
Been thanked: 492 times
Post by waybomb »
This may help, go to youtube, look up boatworx. They have a video on taking apart and fixing them.
And for what it is worth, silicone is useless.
Use boatlife caulk.
Before you run the caulk. Tape any surface the caulk could ooze out onto, and about sixteenth of an inch from each joint. Lay the caulk, run your finger along the bead to flatten it down, removed the tape. Looks factory when done.
In lieu of boatlife caulk, I have used sonolastic np150 white caulk.
We use it in a food plant and it resists all sorts of caustic and acidic cleaners, very quick temperature swings, stays white, and fits not have any growth form on it.
