Early Motorola two wire alternator
Has thanked: 58 times
Been thanked: 446 times
Postby waybomb » July 29th, 2017, 6:59 pm
Anybody have any idea what the ignition wire is for on an alternator found on a 1987 mariner with crusader engines.
Only getting 13 volts output to batteries.
This is a Motorola 50 amp.
It appears to have a mounted external regulator on the back.
I'd like to see if I can fix it.
How do I test the alternators output, unregulated?
Has thanked: 585 times
Been thanked: 1232 times
Re: Early Motorola two wire alternator
Postby bud37 » July 29th, 2017, 7:38 pm
If memory serves me I think that can be used to excite the field.........thats what comes to mind , been a while......need 1500 rpm,should see 14.5 volts at that.....at idle you may just see battery voltage.......... :beergood:
FWIW.....The above is just my opinion..... :popcorn:
Postby waybomb » July 29th, 2017, 7:54 pm
That's what I thought it was for but not sure.
Only have 13vdc at all rpms.
Barely keeping it charged.
Been thanked: 243 times
Postby mjk1040 » July 30th, 2017, 6:43 pm
Sounds like it needs to be pulled and replaced or rebuilt.
Has thanked: 458 times
Been thanked: 1699 times
Postby Viper » July 31st, 2017, 7:08 am
Are you sure it's a regulator or is it a brush cover you're looking at?
Postby waybomb » July 31st, 2017, 10:26 am
Yes it's a regulator.
Motorola/prestolite 8mr2022k bi-directional alternator.
New number 8mr2048ka.
Sent a note to db electric for a price on a new one.
Return to “Electrical”
