1981 3007 Aft-Cabin
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
1981 3007 Aft-Cabin
I have found most of the functional items I need for the boat to run properly. Question, Where is the reservoir for the hydraulic steering located on the 3007 aft cabin model.
I have not been able to locate it so I could check the fluid level.
Thanks in advance.
Thanks in advance.
- Been thanked: 1312 times
Re: 1981 3007 Aft-Cabin
Rick if you have the sea star type hydraulic , it might just be the upper helm mechanism itself....there is a cap to remove to fill it there.
+1
There are a couple of different setups but chances are your helm/steering pump IS the reservoir. If you can see the first few inches of the front of the helm, you'll see a little knob on the top where you fill and check the level, otherwise it'll be a remote fill close by somewhere on the dash above the helm/steering pump.
- RGrew176
Thanks for the information. I will check it out when I get a chance.
- mjk1040
- Been thanked: 248 times
Me thinks u have Hynautic with a pressurized canister some where. It was located in the engine compartment on the port wall of our 1986 Mariner. Happy hunting.
Mike
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
I would guess it is Hynautic based on the age and type of boat. Usually found somewhere near the piston that move the rudders - aft end of the boat. It needs to be accessible, as you sometimes need to add a little oil or pump it up with a bicycle pump. As noted above, it is pressurized. Good luck!
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Lake Norman, NC
- RGrew176
Dual station. The other day I looked under the upper helm station steering wheel. There is a metal block there with 3 hydraulic lines running out from the block. Still looking for the reservoir. Will look more when I have time. I am currently at Put in Bay Ohio for the 2017 I-LYA Powerboat regatta. Lots of events to participate in not much time to look in other areas for the reservoir.
Rick , if you can ,post a pic of the helm, should be a name there somewhere.
