waste system
LarryHedden
Vessel Info: 2004 Carver 560 Voyager pilot house
Has thanked: 2 times
waste system
Post by LarryHedden »
We have a 2004 560 voyager that i would like to install a purasan waste system. has any one done this or have a boat with it installed?
ICANGO
LARRY HEDDEN
Re: waste system
Post by g36 »
if no one responds call raritan and ask for vic he is very knowledgeable and can answer any questions about the install. i had a purasan system on my trojan and it worked great i may be able to answer questions ,but i cant see spending the money on it now on my 405 with 2 holding tanks. maybe someday , pumping out is not really fun but with the new changes in the newer purasan system the cost is pretty steep now. good luck
markncarole
Vessel Info: 1997 Carver Mariner 350
Been thanked: 2 times
Re: waste system
Post by markncarole »
I have a Carver 350 Mariner and I installed a Purisan. I have been extremely happy with it. It has been problem free and it eliminates pump-outs. The only negative is mine uses fresh water instead of raw water, but that is my fault for not re-routing the water lines to the toilet.
Icango560
Vessel Info: 2004 Carver Voyager 560, 675 Volvo’s.
Re: waste system
Post by Icango560 »
Thanks, My 560 has two waste tanks which makes install different. Or two waste systems. thanks
