cruising rpm
Crowbar
Vessel Info: 1987 Carver Voyager- twin 230 hp gas
cruising rpm
Post by Crowbar »
twin 305's, 230 hp on 28' voyager. What is a good cruising rpm? Engines have 1550 hrs.
throwback2
Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Re: cruising rpm
Post by throwback2 »
I have the same boat with twin 230 Mercruisers and usually cruise at 3200-3400 rpm at 22-24 mph.Engines currently have 400 hours.
hausherrs
Vessel Info: 1996 Carver 400
Has thanked: 5 times
Been thanked: 10 times
Re: cruising rpm
Post by hausherrs »
I have heard most people stick around 3200-3400 with all the v8. I have the 454 and I cruise between 3200 and 3400 which is about 20-22 mph. Anything less than 3000 and I feel like its struggling to stay on a plane.
Crowbar
Re: cruising rpm
Post by Crowbar »
Thanks for the info. While I'm at it, what engine temps & oil pressure @ criuse do you see?
MakinTime
Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo
Has thanked: 52 times
Been thanked: 31 times
Re: cruising rpm
Post by MakinTime »
We have a 36 Carver aft with 454's. We go slow most of the time between 1500-2000 rpms (to be easy on equipment) @ around 10 mph. Sometimes cruise at around 3400 rpm and 23 mph not to often though.Our temps stick around 160 no matter how hard I am running them. Oil is around 60 psi.
hausherrs
Re: cruising rpm
Post by hausherrs »
Port temps stick at 160 and stbd 168. Closed cooling.
feeez
Vessel Info: 2001 350 Mariner
Been thanked: 66 times
Re: cruising rpm
Post by feeez »
We have two "sweet spots" in our 350 mariner with 350MPI's.
When want or need to go along at a trawler like speed 2000 RPM will push us along at 8 to 8.5 knots and the boat seems very happy there. The other nice one for this boat is 3000 with a fair amount of trim tab engaged. This will give us 14 to 14.5 knots and a very comfortable ride depending on the conditions. Both of these rates give us very similar fuel mileage.
Cheers
Fraser
Former 2001 350 Mariner owner
Re: cruising rpm
Post by tomschauer »
my 355 with mercury 454's likes to cruise at 3400rpm @ 25 mph +/- depending on the wind. Usually about 175 degrees F, 55# oil. Tabs always up.
jcoll
Vessel Info: 1998 355 Motor yacht
Has thanked: 18 times
Been thanked: 18 times
Re: cruising rpm
Post by jcoll »
Tom and I have the same boat and engine configuration and I (and the boat) like 3200 t0 3400 RPM. Boat runs at 19 to 21 MPH indicated on GPS. Closed cooling system temp = 180F gauge and oil pressure 60# gauge readings. I'll assume prop and trans. gear ratio are the same. I also run tabs up. I don't have any fuel in rear tank and the boat doesn't need any tabs to plane nicely.
