444 CPMY gennie exhaust & port list
Foster15
Vessel Info: 2001 444 cockpit motor yacht
Post by Foster15 »
Morning from Racine. I have a 10 kw gennie with under water exhaust. It also has above water line port aft quarter exhaust outlet. No water comes out of the above water outlet. Is this normal? No evidence of overheating and exhaust is not hot to feel.
Also have about 3 inch port list. Any thoughts on reason or fix?
Thanks.
Foster 15
444 CMY 2001
Racine, WI
Re: 444 CPMY gennie exhaust & port list
Chances are you have an exhaust/water separator. This diverts the cooling water below the water line and the gases/exhaust above. This helps to quiet the belching you usually hear with regular above water exhaust systems.
Here's an example of one:
https://www.westmarine.com/buy/centek--gen-sep-water-separators--P006_180_005_521
DanM
Vessel Info: Carver 396
Been thanked: 35 times
Post by DanM »
As stated above the 444 has a diverted genny exhaust muffler with the water going out the bottom of the hull and the exhaust out the back. As far as the list goes, I believe you have 4 fuel tanks on that model. Two 122 gallon saddle tanks amidships and two 80 gallon port and starboard tanks in the stern. Is it possible the fuel is not evenly loaded? The holding tanks are 36 gallons each and they too are situated port and starboard (not cross connected) so if you are using the master more it is located to the port.
Dan
Carver 396
SugarSand Tango
AndiamoSeattle
Vessel Info: 2006, Carver 4137 CMY, Originally commissioned in 2008, it has spent its last 10 years in the Puget Sound, WA. She features the Volvo-Penta D6, 310 diesel motors (485hr.), 3 zone AC/ Heat pumps, fresh water wash down in bow, bow and stern thruster, 8.0KW Kohler generator, 2/ 30amp shore power input from either mid-ship or stern plugins. Bridge refrigerator ice maker, electric galley featuring an electric oven.
Has thanked: 50 times
Been thanked: 2 times
Post by AndiamoSeattle »
My 4137 CMY has a leak at the base of the fiberglass water/ exhaust tube exiting through the midshipmen hull bottom. There is a screwed on vented panel on the hull bottom. Anyone have experience with this issue? Does this panel have the water tube attached to it?
Sadey
Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto
Has thanked: 4 times
Been thanked: 29 times
Post by Sadey »
Foster you in Reef Point? I'm on W5
Thank you for the help!
Dave & Trina
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Post by Tireless »
Foster15, Viper and DanM are 100 % correct. I have the same boat and this is a great feature.
