Alternator amp question
- Vessel Info: 1989 Santego 2767 mid cabin express
- Been thanked: 2 times
1989 Carver 2767 Santego
1971 v156 glastron modified
1985 whittley cruisemaster
1982 2950 Bayliner offshore express
- Has thanked: 458 times
- Been thanked: 1699 times
Re: Alternator amp question
If you go with something larger than the alternator you have now, chances are you'll have to replace the charge wiring, breaker/fuse, etc. You may even need to change the pulley on the engine. Check the charging curve on the unit you're considering buying. What rpm do you have to be doing before you see full output. If it's not in keeping with your usual boating habits, it may not be worth the extra money.
Weather you need/should go with a larger one depends on your boating habits. They'll certainly charge up a battery faster than a unit with less output but that's only necessary if you drain the batteries a lot and only cruise for short jaunts or run your engines to charge the batteries while on the hook for extended stays. Having said that, you shouldn't be draining your batteries too far down. You certainly won't need them for start batteries.
If you decide to keep what you have, will you replace with new or do you have a place where you can take the failed unit in for repair?
- Has thanked: 72 times
- Been thanked: 1055 times
