1997 Carver 380 Santego
torey
Vessel Info: 1997 Carver Santego 380
Post by torey »
I recently purchased a 1997 Carver Santego 380. I would like to update my cabin windows and noticed that on the 1998 models the windows appear to be 1 piece and more sleek. Has anyone out there replaced their windows? Any advice on where to turn?
Re: 1997 Carver 380 Santego
Welcome aboard. Contact Carver with your hull number. They should be able to provide you with the part numbers and the supplier. Taylor Made might be the supplier. Take a look at the window and see if there is any info etched on it. Usually on one of the bottom corners. Don't know if the windows from a later model will fit but Carver should be able to tell you if that's possible.
Ramsport47
Been thanked: 59 times
Post by Ramsport47 »
The 1998 and later windows will not fit in earlier boats. In the newer system, the mold for the cabin is made to accept the flush mounted windows. There is also aluminum supporting built into the cabin structure.
Kenny
T-Merc 350 Mag MPI (300hp)
