Carver 356 RPM issues
- cpoint
- Has thanked: 208 times
- Been thanked: 26 times
Re: Carver 356 RPM issues
- cpoint
One other thing, I have good deal of growth under the boat mostly moss like stuff. But I believe that will affect maybe 1 or 2 knots. Definitely issues on port side still. Almost everything been replaced on port side. Not sure where I can find a better mechanic
Also I still have bad stuff in fuel, need to get that cleaned for the 4th time AARRRRGGGGHHHHHHHH!!!!!
- Has thanked: 579 times
- Been thanked: 1210 times
Man you sure are snake bit with this one though, good luck with it.
- mjk1040
- Been thanked: 242 times
- cpoint
- hausherrs
- Vessel Info: 1996 Carver 400
- Has thanked: 5 times
- Been thanked: 10 times
Fuel cleaning would be a waste of money that would be better spent on some good gas water separators / filters. The crusader has what everyone calls "Racor water separator"... Its not really a water separator or at least it never separated any water from my fuel!
I installed two Racor 500 MAM (The only Racor 500 USCG approved and only 500 approved by Racor for gasoline) and all my fuel problems were gone.
- cpoint
hausherrs wrote:Source of the post Are you still using factory fuel filters? And do you have Merc or Crusader engines?
Thanks. Not sure they are factory filters. I get them from Amazon. Thats what I had on them when I purchased the boat. At this point I do not have water in fuel issue. I had it emptied completely. Since I do not see water in the fuel when I replace the filter. I do see brown dust like stuff. Last time I had it filtered, they got quite a bit (handfull) out. But I think there is still some there which gets loose and into the filter. And I think at this point it may have gone past and got into one or more fuel injectors. I am running out of options in getting it cleaned completely. I need to find a way to filter it out myself. But maybe solution is what you are recommending. I will look into it. I am using: 35-802893Q01 Fuel/Water Separating Filter Quicksilver/Mercury
- Been thanked: 1043 times
- cpoint
- mjk1040
