Bilge pump circuit breaker
sep4086
Vessel Info: 1990 3867 SANTEGO
2003 PRO LINE 26 WALK
Has thanked: 2 times
Postby sep4086 » November 5th, 2017, 4:11 pm
I am looking for a replacement circuit breaker for the auto bilge pump circuit. The switch is located under the stair leading to the back deck on my 1990 3867 Santego.
Been thanked: 622 times
Re: Bilge pump circuit breaker
Postby g36 » November 6th, 2017, 11:42 am
Have you pulled it out? Should be easy enough to cross reference. I'd numbers on side and same amp there should be a few companies to pick from
sep4086
Postby sep4086 » November 6th, 2017, 1:35 pm
I will have to pull it out. It looks like a regular on/off toggle switch but it is also a circuit breaker. I think that I have to take the stair apart to get at the wires.
Been thanked: 1055 times
Postby km1125 » November 6th, 2017, 4:53 pm
You can also email Carver and they can probably tell you the make and model of the breaker they put in when the built the boat, assuming it was a standard installation.
Been thanked: 243 times
Postby mjk1040 » November 8th, 2017, 5:03 am
U sure it's bad? Maybe the bilge pump is bad and drawing to many amps? If u can exchange it with same amp size and see if it is the breaker before replacing.
sep4086
Postby sep4086 » November 8th, 2017, 5:49 pm
I have already changed the bilge pump because it was locked up and I also changed the float switch.
Postby mjk1040 » November 11th, 2017, 6:11 am
In that case u may have fried the breaker or the new bilge pump draws more amps then the old one?
Return to “Electrical”
