396 aft holding tank and lines
Topic author - Scurvy Dog
- Vessel Info: 2000 396 aft
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: 396 aft holding tank and lines
..Aaron
SeaDragon
- DanM
- Vessel Info: Carver 396
- Has thanked: 5 times
- Been thanked: 33 times
Good luck,
Dan
Carver 396
SugarSand Tango
- Vessel Info: 2003 carver 396
We assume the aft tank is vented to the outside but we cannot locate that vent. Any suggestions? We have looked at the parts manual online without success.
Regards,
Deb and Mark
- Has thanked: 579 times
- Been thanked: 1210 times
http://www.marinesan.com/TankSaver-Reli ... 255247.htm
- DanM
Good luck
Carver 396
SugarSand Tango
- Has thanked: 455 times
- Been thanked: 1671 times
Tx5311 wrote:Source of the post....When we take the foam insert off the top of the tank we see straight through to the tank. Is this normal......
You should not be able to look into it and see the inside of the tank if you're looking into the relief valve unless you removed the valve itself. It's a two piece unit; the tank flange and the valve body that is pushed into the flange. The valve body contains a few parts. Here is an example of the two pieces:
http://www.ardemco.com/accessories/sealand-dometic-313255247-tanksaver-holding-tank-relief-valve/
If the valve is worn, you will get odors in the cabin.
- mjk1040
- Been thanked: 242 times
Users browsing this forum: Bing [Bot] and 225 guests
