Custom Underwater Lights.
- Has thanked: 269 times
- Been thanked: 1153 times
Waterproof T connectors so I end up with a single wire going through the transom to supply power. They are a little better than an inch thick and 5" in diameter. Should illuminate the depths quite well to say the least. Total cost is under $100 for all 4 however I do have access to a machine shop so the machining is free.
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
Re: Custom Underwater Lights.
- Has thanked: 580 times
- Been thanked: 1210 times
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
..Aaron
SeaDragon
Here are pictures of the main underwater custom led installed on the trim tabs.
Installed blue mood lighting 7x, 10W strips along the transom just above the water and 2x, 12 watt led under water spotlights to give a cool factor.
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
Ya know the saying....no pictures....didn't happen....
- Has thanked: 324 times
- Been thanked: 595 times
