Shower Door Handle
eburklo
Vessel Info: 2003 Carver 564
Shower Door Handle
Post by eburklo »
We own a 2003 Carver 564. The bifold shower door in the bow of the boat is missing a handle. Looks like the handle is 7inches long and has 2 screw at each end 1/2 inch apart. Any recommendations on where I can get the shower door handle replaced?
Been thanked: 492 times
Re: Shower Door Handle
Post by waybomb »
Try Carver. In the past I've never had any luck getting anything out of them, but several here and on other sites were able to buy OEM hardware from Carver or a Carver dealer.
Kendors in Wisconsin buys alot of surplus from Carver, you may try them if Carver ends up with a dead end. On the internet, Kendors is also Great Lakes Skipper.
Ramsport47
Been thanked: 59 times
Post by Ramsport47 »
I would try Carver first as Fred suggested. If nothing else, they can give you the manufacturer and model number (exact) for the item you need. Be sure to have your hull ID number so they can look things up for you.
Kenny
T-Merc 350 Mag MPI (300hp)
